When we try to flash a new RoboRio it fails 1/2 way through saying unable to download image to target. The possible solution says put the roboRIO in safe mode which does not work. we get unable to complete operation because of unexpected error: Error -2147220335 occurred
If you’re flashing a Rio 2, you must image the SD card first (which then also avoids the need to image at all, except to set the team number).
thank you we will give this a try
Is this a roboRIO or roboRIO 2.0?
Robrio2 - the attached instructions worked
