Was wondering if anyone knew of a material that could bend completely and is tough so it could pick up ones of those “moon rocks or empty cells or super cells”
We were thinking of using foam but the problem of using foam is that we need another motor and we want to keep it with just one motor.
Thank you :)! 1872 I think its the number of my team not really sure…
My team was thinking of making a conveyor belt with a flexible material attached to it, so for when it reaches top. The top will bend the “material” and lets go of the ball. Falling into a chute and then restoring its original shape or similar. Shape of a hook but not so curved.
Well if it need to be plastic, then just go to the store, and buy some of the tubberware* That stuff can be adjusted with heat, and is really sturdy.
*I am not sure if that is the exact name, just pretty much look for the huge bowls that people store food in that are plastic. Or debate tubs will work too.
Could have forks protruding from the belt on springs of some sort so when it hits a solid something it bends back and releases again as it goes back down.
I found something better, our team is using somekind of polycarbonate sheet. They needed it to bend, so we took a propane torch and heated it up for a while, and it worked well.
