I’m wondering how this mechanism works and if anyone in FRC has done similar. With the theory of “Going up stairs to a stage” as a possible challenge in this year’s game, I think learning about this might be valuable. Any thoughts?
I also just picked up one of these off mercari for $32. If no one knows I’m gonna tear it apart and figure it out the old fashioned way.
Edit: I’ve seen this style of adjustable tank outside of FRC but I can’t recall seeing it IRL at an FRC event. Other examples
So one hollow shaft connected to the tread pulley for both sets on one side. Then another shaft inside of that which controls the rotation of the flipper through that side plate?
The bumper zone is definitely a limiting factor, but in endgame that rule usually is waived. Like 2019 hab. Maybe if it only swings under the robot perimeter and not outside of the extension limit?
The shaft for the outer pivoting drive section is also a live axle that everything rotates on.
We did something similar to this on our 2010 robot see the pictures below. We used a live hex axle to drive everything. The full system was contained below the bumpers
Still going strong! That’s the project I spend a majority of my time working on. We actually just created a new ~1/2 weight and waterproof version for MARSOC.
