Flywheel Program
I need to find a way to make a joystick button code for the flywheel in LabVIEW. There is no subVI for a button code, so is there something similar?
The buttons are accessible via an array from the Joystick Read just like the axes.
I might also add that there are some examples of using a button to toggle an output (like a motor) at the bottom of this article:
https://www.frclabviewtutorials.com/tutorials/memory-library/
You might also want to read:
There’s a good chapter about state machines, and it also explains how to achieve toggle buttons.
