Follow method help
We are trying to replace MotorControllerGroup with the .follow() but it is throwing an error. Could you help us. Thanks
// motor controllers for each arm ellement
    public CANSparkMax LupDown = new CANSparkMax(ArmConstants.kLUpDownMotorPort, MotorType.kBrushless);
    public static CANSparkMax RupDown = new CANSparkMax(ArmConstants.kRUpDownMotorPort, MotorType.kBrushless);
    public CANSparkMax lShoot = new CANSparkMax(ArmConstants.kLeftShootMotorPort, MotorType.kBrushless);
    public CANSparkMax rShoot = new CANSparkMax(ArmConstants.kRightShootMotorPort, MotorType.kBrushless);
    public CANSparkMax intake = new CANSparkMax(ArmConstants.kIntakeMotorPort, MotorType.kBrushless);
    // TODO Invert
    // TODO use .follow() instead of MotorControllerGroup
    // group of the shooting motors
    LupDown.follow(RupDown, ture);
    lShoot.follow(rShoot, ture);
It would be a lot easier to help if you posted the error.
You have a typo
I fixed the typo and there are more errors:
Syntax error on token "(", delete this tokenJava(1610612968)
Syntax error on tokens, VariableDeclarator expected insteadJava(1610612973)
Here is the whole file. There are other errors but I think I know how to fix them after we get the follow method working.
package frc.robot.subsystems;
import com.revrobotics.AbsoluteEncoder;
import com.revrobotics.CANSparkMax;
import com.revrobotics.CANSparkMaxLowLevel.MotorType;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.motorcontrol.MotorControllerGroup;
import edu.wpi.first.wpilibj2.command.SubsystemBase;
import frc.robot.Constants.ArmConstants;
public class ArmSubsystem extends SubsystemBase{
    // TODO Invert
    LupDown.follow(RupDown, true);
    lShoot.follow(rShoot, true);
    //public final MotorControllerGroup shoot = new MotorControllerGroup(lShoot, rShoot);
    //public final MotorControllerGroup upDown = new MotorControllerGroup(LupDown, RupDown);
    //Encoder
    public final static AbsoluteEncoder upDownEncoder = (AbsoluteEncoder) RupDown.getEncoder();
    // Timer
    public Timer Armtimer = new Timer();
    public void armMove(double upDownSpeed, double shootSpeed, double intakeSpeed){
        upDown.set(upDownSpeed);
        shoot.set(shootSpeed);
        intake.set(intakeSpeed);
    public void joysticMove(double upDownSpeed, boolean shoot, boolean intake){
        double outshoot = 0.0;
        double outintake = 0.0;
        if(shoot){
            outshoot = 1.0; //default commands
        else if (intake){
            outintake = 1.0; //default commands
        outintake = intakeCheck(SmartDashboard.getNumber("IR", 0.0), outintake);
        armMove(upDownSpeed, outshoot, outintake);
    public void armMoveTime(double upDownSpeed, double shootSpeed, double intakeSpeed, double time){ // I think seconds
        Armtimer.restart();
        while (Armtimer.get() < time){
            armMove(upDownSpeed, shootSpeed, intakeSpeed);
    public void armMoveAngle(double degAngle, double shootSpeed){
        double rottations = angleToRotations(degAngle);
        while (upDownEncoder.getPosition() < Math.abs(rottations)){
            if(rottations < 0){
                armMove(-1, shootSpeed, 0);
            else if(rottations > 0){
                armMove(1, shootSpeed, 0);
    public double intakeCheck(double IR, double initSpeed){
        if(IR > 20.0){
            return 0.0;
        return initSpeed;
    public double angleToRotations(double degAngle){
        return 0.0;
You can’t call methods like that outsode of a function scope. Move the two .follow(...) calls to the constructor
Thank you for the help
