According to the given parameters the tangential, the radial and the axial forces on the gear will be calculated. The distance of the gear to the bearings and direction of the axial force will be determined by the student. The gear width should be chosen by the student considering the key length.
It is asked to design the shaft considering the shaft surface conditions and the assembly requirements.
The bearing of the shaft will be performed by means of ball bearings. In bearing selection take Lh=15000 hours.
Each student should use the values of his/her own given in the table. All the calculations and the technical drawings should be given in the project report.
Can you help with this issue?
