Frc 8724 presents CADvent
Here’s week one of 2024’s CADvent counting down to kick-off a little late:
Upcoming CADvents will be posted on a daily basis.
Cadvent Day 1.pdf (119.4 KB)
Cadvent Day 2.pdf (90.5 KB)
Cadvent Day 3.pdf (121.0 KB)
Cadvent Day 4.pdf (128.8 KB)
Cadvent Day 5.pdf (131.0 KB)
Cadvent Day 6.pdf (150.7 KB)
Cadvent Day 7.pdf (114.3 KB)
CADvent pdf files will be kept in this Google Drive folder:
https://drive.google.com/drive/folders/19jcqBpv-zi3WIuUR2YlwJV__T5v7l3B8?usp=drive_link
awesome to have the cadvent back!
Cadvent Day 8.pdf (137.4 KB)
This is one of my favorite yearly threads. Love me some CADvent! Thank you for doing this.
Cadvent Day 9.pdf (128.1 KB)
CADvent Day 10 is an Assembly:
Cadvent Day 10 Side Plate.pdf (109.0 KB)
Cadvent Day 10 Bearing.pdf (91.6 KB)
Cadvent Day 10 Hex Shaft.pdf (86.6 KB)
Cadvent Day 10 Wheel.pdf (88.0 KB)
Cadvent Day 10 Assembly.pdf (439.8 KB)
CADvent Day 11 (1).pdf (106.2 KB)
Cadvnet Day 12.pdf (106.1 KB)
Cadvent Day 13.pdf (122.3 KB)
Cadvent Day 14.pdf (102.4 KB)
Is there a missing dimmention here? Are we to assume the nose piece is the same offset as the arms?
Good catch! I forgot this dimension, but yes, the offset is the same.
Cadvent Day 15.pdf (113.2 KB)
Thank you for putting this on. There are some drawings missing dimensions. Day 3, 6, 8, 9, 13, and 14 have undimensioned elements. Many others have assumed dimensions which is not best practice. It leaves room for misinterpretation and mistakes.
Thanks! As I am a one-man crew, I appreciate you helping me catch these missed dimensions! I implore more of those, who find that they must assume dimensions because I forgot them, to let me know. Thank you again, and happy CADing!
Cadvent Day 3 Corrected.pdf (147.5 KB)
Cadvent Day 6 Corrected.pdf (163.5 KB)
Cadvent Day 8 Corrected.pdf (139.8 KB)
Cadvent Day 9 Corrected.pdf (144.4 KB)
Cadvent Day 13 Corrected.pdf (130.1 KB)
Cadvent Day 14 Corrected.pdf (106.5 KB)
Cadvent Day 16.pdf (128.4 KB)
Cadvent Day 17.pdf (148.2 KB)
day 15 has 2 arcs near the top that are undefined in degrees. i used a lot of constraints to make the model but was wondering if there were meant to be dimensions for them.
