Letâs talk about statistics Part III!
@StephenWitwick, @Wesley, @JWC_95 , myself, and a few other Grasshoppers did a big experiment today to evaluate different shooter wheel configuration. It includes high speed video, pictures, and lots of data. This is pretty firmly the biggest and most useful experiment we have ever run and published.
The intent for this experiment was to capture the approximate performance differences between major shooter archetypes, NOT to provide an optimal design for one particular choice. There are SO MANY details that I cannot capture in this post, but if you see something say something and post about it! A lot of this experimental setup is not ideal, we know that, and we would expect all designs to improve consistency if they were executed more cleanly. We also didnât try to control every single variable independently. So, yeah, we change wheels and the inertia changes in the system. Use your best judgement when interpreting or applying our results.
Experimental Setup
Shooter specs:
- 1x MiniCim per axle wired to 12v nominal
- Fresh battery every 1-2 configurations
- Shooter positioned 30° from horizontal
- 11.5ft range
- 4in Colson wheels, 3in 35A stealth wheels
- 1/2in nominal compression
- 1x worn out legal Note, 1x fresh legal note (fresh note used in all HSVs), 5x off-brand notes; all notes cycled ~3 times per configuration
- Shooter bolted to platform with 120lbs of sand for recoil absorption, wheels taped to the floor
- Window wire grid is 1/2in on center
- HSV shot at 1080P/1kfps, so if you watch if frame-by-frame each frame is 1ms
- Positional data collected from tape marks via pixel counting, each image calibrated by counting 12in near the center of shot spread from window wires
- Shooter plates modeled here
Configuration 1
2x Colson wheels offset to one side
This was tricky to feed well, the note wanted to pop out of the wheels, as seen in HSV 1 - flub clip.
[no direct picture taken, see setup pic above]
Shot spread:
Configuration 2
4x Colson wheels offset to one side
Easier to feed, note didnât seem to âpop out of the sideâ as much
Noticeably more inertia in shooter
Shot spread:
Configuration 3
4x Colson wheels spread out for a âno spinâ shot
Wheels spacing is admittedly not ideal for this configuration
Fed okay, felt easy-ish to slip left and right
Shot spread:
Configuration 4
2x Colsons, 2x Stealth, tapered axles (both sides 1/2in compression nominal)
Easier to feed
Noticably more power
A few flubbed shots traced to off-brand note (green one), eliminated as outliers
Image below is not an optical illusion
Shot spread:
Configuration 5
4x Colsons with 1/2in nominal compression, 4x Stealth with 1/2in nominal gap
Feeding seemed easy
Substantially more power vs 1 and 2
Shot spread:
Configuration 6
A combination of 4 and 5
4X Colsons with 1/2in nominal compression, 2x Stealth wheels with 1/2in nominal compression, 2x stealth wheels with 1/2in nominal gap
Tremendous power, easy to feed
Two shots maybe should be tossed as outliers, but maybe not⌠kept in analysis
Image below is not an illusion, inner axles are tilted
Shot spread:
High speed video
1-3x examples of each configuration with the same good-condition offical/legal Note
1kfps
Analysis
I used a Standard Deviations test to compare all six datasets.
Overall it shows at configurations 4, 5, and 6 compare similarly and are all superior to configurations 1, 2, and 3. I suspect that configuration 6 could be tuned a tiny bit more to be an absolutely devasting sniper shot, and 4 and 5 could be improved substantially as well. Additional flywheel inertia and careful application of slippery materials may be helpful for all of these designs.
We are going to continue to plan on using a design derived from Configuration 4, but with independently driven 3in stealth wheels instead of tilted axles. The reduced number of axles improves packaging and total weight without an detectable sacrifice to accuracy or range.
