I had an idea for an interesting draft process instead of the normal snake, instead use an auction draft. This was inspired by fantasy football drafting, but modified for FRC.
At the end of the qualifying matches teams are ranked just like they are today, but instead of getting a draft pick, they are given draft points to bid on teams.
First: 20 draft points
Second:19 draft points
Third: 18 draft points, ect.
The draft then begins by asking the first ranked team to put up a team number and an initial bid. The other top 8 ranked teams can then choose to raise the bid on the team up for auction until no team is willing to go higher. (Still trying to figure out how teams would enter bids). Next the second ranked team would put a team up for nomination and the process would repeat until all alliances are formed.
Rules:
1)Teams in the top 8 can be put up for auction, but the minimum price is the draft points they earned (second seed must be bought for 19 draft points or more, third for 18 or more ect.)
2)Teams can refuse to go up for auction (Top 8 may want to form their own alliance or teams may hope to get bumped into the top 8), but can not be nominated later if they refused once
3)Teams give up their earned draft points by accepting a bid nomination
4)Teams move up an earn more draft points if a team ahead of them is selected (If a team ranked first, buys the second ranked team for 19 points, the third ranked team receives a total of 19 points (one additional from their 18), fourth rank 18 points, and down the line)
5)Teams can put up an initial bid of 0 points, if no one raises the bid they receive that team for free (allows for teams to spend all their points on 1 team)
6)Full Alliances can not nominate or bid on teams
8)The nomination process is in snake form (1-8, 8-1, 1-8, ect) until all alliances are filled (skipping full alliances)
Advantages:
1)Deeper level of strategy for alliance captains
2)Allows alliance captains to get a team they wanted, if they are willing to pay
3)Balances Alliances?
-The cost of obtaining a partner is closer to their worth
-Currently picking “The best” robot available might only be marginally better than the next 5, but costs a much higher pick. In the new alliance selection, all 6 robots can go for the same or similar prices
Disadvantages:
Will take a lot longer
-A nomination could have it’s price raised 18 times -
Confusing and complicated
-Unprepared teams may struggle to evaluate the worth of a robot
I doubt we will ever see this type of draft happening, but it is interesting to think of the strategies that could form:
-First ranked team getting two 10 point robotics instead of a 19 and 1
-Nominating teams you don’t want so others will use up their draft points
-Nominating your “second” pick equivalent before your “first” pick
-If it is four team alliances, do you save points for a better back up?
