FRC build.xml
Hello there,
When I press “RUN”, the robot code launches the build in eclipse but once it finishes, it displays
“C:\Users\6046\wpilib\java\current\ant\build.xml:345: Remote command failed with exit status 1”
Thanks in advance
Does it still say build successful or does the build stop and fail?
There should be more text above it. Can you post the full log?
