Frc DashBoard
i have no really experience with Ni Labview but would like to build a dash board any suggestions on were to start?
The following link should have what you’re looking for (Thanks to Greg McKaskle for the correction):
A real plethora of resources on this site. Should have everything you need.
contains many of the newer tutorials.
Greg Mckaskle
The dashboard went through a major rewrite this year. Unfortunately, that makes that tutorial obsolete.
Thanks to both of you for the update. I’ll change the link to avoid any confusion.
i feel like there is something i am missing i have not been able to find any parts in the pdf which talk about writing the robot code in C++ and then taking the C++ calls and making them available in labview that way i can interface them with gauges for the dash board
If you use the C++ version of the dashboard on the robot, you can connect to it from the LabVIEW dashboard simply by naming the variables the same. To connect a LabVIEW gauge to a variable, you simply place it in the tab control on the dashboard and give the control the same name as the variable.
Greg McKaskle
thanks for your help i will try what you said today and i am also having trouble centering the dashboard in the run window.
Thanks in advance
