Hello CD!
We seem to be running into issues using the new characterization tool on our test bed chassis. The setup consists of 4 Spark MAX’s with associated NEOs, two per side with one specified as follower.
Left - CAN ID 3 follows 2
Right - CAN ID 5 follows 4.
When deploying the following setup, the follower’s are not moving. The signal is being sent to the leader’s correctly.
When defining both sets of motors individually (not set to follow), motor group 0 continuously gives the correct signal. However, motor group 1 (normally the followers) will periodically pause and give a stop signal (green blink to blue solid) every half second or so.
(Can’t post two images)
Motor Pair 0:
L - 2 - Not Inverted
R - 4 - Inverted
Motor Pair 1:
L - 3 - Not Inverted
R - 5 - Inverted
In 2020 we were able to set the follower state and define the controllers manually in the generated java project, however now that’s not the case. Has anyone seen similar behavior to this? Any tips or guidance is appreciated.
