Does anyone know if i can launch the software to set up the bridge and router without first having to reset them to factory, i would like to check the status of the IP etc?
also is there any place i can buy another drivers station?
thanks John
thanks John
You can still log in to the bridge per the original instructions, you just need to use its new IP address. If you do not know its new IP address, you will likely have to reset it to factory defaults.
The 2010 driver station is sufficiently different from the 2009 driver station that purchasing an 09DS would likely be a waste of funds.
ok thanks on both accounts
