Today the version 28 came out for the crio imaging tool.
When I opened the folder their was no exe, just txt files and some config files. I downloaded this update from first forge, but my question is how am i suppose to install the updates?
thanks
thanks
On the desktop of your Developer account should be a cRIO Imaging Tool. Plug an ethernet cable from your computer to the cRIO and run it. If you’re not already in the cRIO Images folder, navigate to
C:\Users\Developer\sunspotfrcsdk\cRIO_Images
You’ll see a file called FRC_2011_v28.zip. From here, let the imaging tool do it’s thing and you should be fine.
I checked the CRIO-images folder and version 28 zip folder is in there but when i open up the imaging tool it says that the available image is Version 27 to send to the robot. so what do i do?
Did you have your robot updated to v27 prior to updating to v28? I don’t think you can simply skip them like that.
We already had updated the CRIO to v27
Team 3011 here.
We are having somewhat the same problem.
After we got the classmate to locate the updates, we tried to run the cRIO imaging tool.
For some reason v28 comes up with errors saying that the current IP address is used.
Our classmate IP is: 10.30.11.5
Subnet: 255.0.0.0
