hello everyone,
When I deploy my program, even though I can build the program, the robot code does not come and I get these errors.
My program is as follows. https://github.com/wusled/aa1-Imported.git
I will be very happy if you review it and tell me my mistakes.
It looks like there’s a bug in your code, hence the NullPointerException at line 98 of Swerve.java, but the link to your code is broken.
Is the repository private on GitHub?
i m sorry yıu can run it now https://github.com/wusled/aa1-Imported.git
The issue is here:
You are trying to create the odometry using the module positions before you define the modules. Swap the swerveOdometry and mSwerveMods definitions and it should work
I know the question has been answered, but here’s an example of the debugging process:
Here’s the offending line and the context:
96 public SwerveModulePosition[] getModulePositions(){
97 SwerveModulePosition[] positions = new SwerveModulePosition[4];
98 for(SwerveModule mod : mSwerveMods){
99 positions[mod.moduleNumber] = mod.getPosition();
100 }
101 return positions;
102 }
So, the first line of the stack trace is saying, “cannot read the array length <on line 98> because the array is null”. mSwerveMods
is what I would guess to be the array, based on the context.
Searching the file, I find near the top:
21 private SwerveModule[] mSwerveMods;
Confirming that it is an array, and that it is not initialized on the same line as it is declared. Where is it initialized? Searching for that:
25 public Swerve() {
33 mSwerveMods =
34 new SwerveModule[] {
35 new SwerveModule(0, Constants.Swerve.Mod0.constants),
36 new SwerveModule(1, Constants.Swerve.Mod1.constants),
37 new SwerveModule(2, Constants.Swerve.Mod2.constants),
38 new SwerveModule(3, Constants.Swerve.Mod3.constants)
39 };
43 }
Which shows that mSwerveMods
is supposed to be initialized in the constructor of Swerve
. So, why is it not initialized by the time your code runs?
Looking back at the stack trace, the next line reads:
at frc.robot.subsystems.Swerve.<init>(Swerve.java:30)
says that getModulePositions
was called from line 30.
So, expanding the context from earlier:
26 gyro = new Pigeon2(Constants.Swerve.pigeonID);
27 gyro.configFactoryDefault();
28 zeroGyro();
29
30 swerveOdometry = new SwerveDriveOdometry(Constants.Swerve.swerveKinematics, getYaw(),getModulePositions());
31
32
33 mSwerveMods =
39 };
43 }
And the rest is covered by @Ankur-Raghavan 's post above.
Can you show with arrows on the image which command lines should be replaced?
swerveOdometry = new … should be moved under mSwerveMods = …};
That’s because you’re referencing getModulePositions() (which uses the modules from mSwerveMods} before creating mSwerveMods itself, resulting in a NullPointer error.
I will try this tomorrow. Thanks for your answers.
My other question is which line of code can I write instead of this old code?
Replace whenPressed
with onTrue
- those functions were renamed for 2023 and the “pressed”/“active” variants were deprecated.
