FRC Java pre-made clases
Our team started coding with Java for the first time this year and we were wondering where NetBeans stores pre-made classes (such as RobotDrive).
Thanks
Are you refering to the WPI libraries location? They should be where you installed them to. (on linux it defaults to /home/user/sunspotfcrsdk/) The WPI jar is in the /lib/ folder. For convenience, our team hosts the file here. Source code and javadocs are here.
Hopefully that helps.
If you need to install them, here is a link to the XML file to input into Netbeans: http://first.wpi.edu/FRC/java/netbeans/update/updates.xml
