I configured the radio access point with the firewall enabled to simulate how the game field control system behaves but found I could still download code to the robot which its supposed to stop ??
Anyone else found that ? Does that mean the firewall has not been successfully configured to block any ports or that the config just accidentally left the programming port open ?
So that’s true - even though the documentation says this ?
“The “Firewall” option configures the radio to emulate the field firewall. This means that you will not be able to deploy code wirelessly with this option enabled.”
