FRC Ri3D at Penn State 2024 Build Thread
CAD Finished!
Our CAD is now finalized for our robot Whiteout! So feel free to ask questions about it.
The Onshape is saying the access is denied. Also, I LOVE that intake design! Very innovative, and the way you showed the process, not just an overview, is very for me trying to understand it! Thank you :slight_smile:
link should work now. I was able to view it without signing in.
Hello, my team and I loved your design, and we also have a question, What was the gear jump you used on the arm to score on the amp?
not sure which gear you are referring to so I’ll list all the gear ratios
arm pivot: 36:1 from planetary + 4:1 from belt, 144:1 total, 2 NEOs
arm intake: 5:1 on NEO
arm eject: 20:1 on NEO 550
climb: 100:1 winch
Our Last Big Post :frowning:
Thank you all for following along with our progress this past week. We hope that these showcase videos below will provide your teams with a closer view at our main three mechanisms. As always, keep asking questions in this thread and we’ll try to respond promptly. Ri3D at Penn State wishes you all the best of luck during your build season and competitions this year!
Climb Showcase
Intake Showcase
Arm Showcase
Did you guys use a dead axle or a live axle?
We used a dead axle. The pulleys connected directly to the arm with 4 bolts each
I know I taught you the difference between an axle and an axel :wink:
Do you have a bill of materials for easy access?
We have our BOM for the entire season, but we don’t have one for exactly on the robot. It was made with a lot of Rev Max extrusion and other rev ion parts, along with some black anodized T-slot. Here is the BOM for the season.
What is the starting configuration of the robot and can the robot start with a part of the robot outside bumpers.
It cannot. The robot starts with the arm up. We can achieve this by setting the arm to coast, raising it, and then setting it to break.
Hey! What angle is the robot arm at when it is in shooting position?
We have it hit a hard endstop at 0 degrees and in the scoring position, but I don’t know the angle, but you could get the exact measurement from the CAD.
