http://www.highlandersfrc.com/RobotImages/Magnetar_2016.JPG Specifications Drive Train
Vexpro two cim gearboxes
Overall gear reduction High:9.167:1 Low:20.833:1 Intake
Driven by a bag motor with a 25:1 gear down. Picture is not updated, there will be a 4" mecanum wheel on each side with two versawheels in the center. Catapult
NOT SHOWN IN PICTURE
There is two 6 in. stroke and 1.5 in. bore pistons driving the catapult with a latch to pre-charge the system. There are two ballast tanks that are dedicated to fill the pistons. Defenses that can be crossed
B and D defenses along with the low bar.
Originally Posted by Michael 4499 View Post
It is a lot of fun, 20 ft/s is really fast!
That is very fast!, does your robot get air(Dukes of Stronghold) when going over certain obstacles?
JVN Calc says that your low speed is about 7 ft/s
Which speed(high or low) are you using/planning to use the most?
We definitely can get some air, but more than likely we will be using low gear to go over the defenses so it isn’t so hard on the robot. We will use high gear to go through the low bar and secret passage.
