Team 971 proudly presents our 2018 robot, Curiosity, which will be competing at the San Francisco and Silicon Valley regionals in California. Special thanks to everyone who made this robot possible!
If it was something I would have expected from 971 then it wouldn’t be a 971 robot. Year after year you all make machines that surprise and inspire me. Good luck this year!
Honestly, feel the same. This robot is absolutely fantastic to watch. The controls code behind these “transformer” robots must absolutely exciting to write. 971 never fails to impress!
Wow! Such a well thought out and well engineered design again. Watching those intake arms swivel in and out is mesmerizing. It’s a very smart choice to have the (heavy) active intake mounted on the chassis so that the arm only has to lift a relatively light pneumatically operated grabber.
Is this the only design where the arm is offset to one side? The “grabber” for the cubes is still centered so there is no need for the arm to be centered also, as long as all the joints are designed properly.
Yes it is, but no it won’t, because of straight up coding wizardry. The code that controls that robot puts entire companies of programmers to shame.
There are 3 technical areas to have total mastery over in FRC(my opinion)
Electrical (see 1538 Holy Cows wiring)
Mechanical (see 254 Cheesy Poofs design integration)
Programming (see 971 Spartans robots never exploding due to a bug in the code)
