FRCTop25.com- Submit Your Picks for Week 1!
I think there is value in the elims data to see what a good team can really do when put with other good teams, but not for the round 2 picks if that is possible. There was inflation, but also compression of the spread. That shows that the separation of the better teams might not be so much when playing at higher levels and team play is key.
Unfortunately, for me there’s no easy way to do this. As a twitter post comes in, I update a running sum for a given team. Unfortunately the alliance selection is not posted to twitter. Maybe something they could add to the twitter feed next year. I’m still trying to get autonomous added to it too.
If they ordered the teams on the twitter feed based on alliance selections, then I could do this, however that is not the case this year.
There are two other teams that pulled of a double autonomous… 326 and 148… and I wouldn’t be surpised to see 1114, 111, 330 or 254 having one either…
Awesome! Yeah I don’t think the limit factor on a double autonomous is programming, its actually fairly simple to code it up given the right sensors.
The limiting factor is having a very well designed robot. This is why I’ve always shot for the design requirement “Design for autonomous”… because if it can meet the goals of autonomous, its probably simple enough for the drivers to use quite well.
It’s awesome to hear that so many of top 25 teams are getting there based on focusing on building great tube hangers, rather than great minibots. Also it seems teams who chose not to pick up from the field (my team included) made a huge mistake. Is anyone aware of a top 25 team that can’t pick up off the floor?
From the week one regionals, if you couldn’t pick up from the floor you were probably a runner and a late third pick during selection… Plus with so many tubes on the ground, I don’t see you wouldn’t… If I was on your team, I would consider changing to one if possible…
From what I saw, HYPER 69 was unable to pick up from the floor or preferred to obtain tubes from the feeder station.
Buzz Robotics 175 is able to pick up from the floor but prefers to be fed as well. We did not use the “flipper” at all during the competition.
We found it more effective to keep the floor clear of tubes in order to negate the opposing alliance from stealing the tubes we threw out.
Yeah, our seasons over. Honestly one of our many poor design decisions. We live and learn. For me it was a great year to test my autonomous structure and made a lot of forward progress. I also now have a long list of requirements for my code structure.
Now its time for me to work on my ranking algorithm, its okay but could be a lot better :slight_smile:
yeah I’m thinking this was a big difference between BAE and the other competitions. Unfortunately i think the teams were weaker at BAE this year than some of the other regionals. Also the BAE strategy seemed a lot different from the other locations too.
Just for example, the best BAE teams averaged around 60, where as 217 averaged 85 points per qualifying match and 2056 almost 80. Come the championship, if you want to play with the big boys, you’ll have to be able to pick up off the floor, and have autonomous too.
Your season is never over… I would continue to improve that robot and teach those on your team… Learning is what comes of a regional, plus it doesnt hurt to have something working for an offseason event… Use that robot as a great tool for the 2012 season…
The average may have differed greatly but there are different ways this data may be perceived. It could mean that the teams were “weaker” or that they were better balanced with respect to one another.
Like you stated, the strategies at the regionals varied and the presence of tubes from both alliances in a central location compared to that of playing conservatively will result in different results.
There is a thread about the highest score that refers to 148 and their partners scoring 135, but the opposing alliance with only a mere 8. Compare that to the first finals match at GSR with 117 over 82 and you see more of a balance. What were some of the finals scores at FLR,Alamo, NJ, and Kettering? I’d like to see some of the results.
Quarter Final 1, Match 1 (1 vs 8) at kettering… ended 114-79
probably the best two alliances in that elims…
the top NJ score:
red score:124 blue score:22 red :1860 25 1923 blue: 1089 1647 102 red mini:50 blue mini: 0
top alamo:
red score:135 bluescore: 37 red: 3481 16 148 blue: 57 2848 245 red mini:50 blue mini:25
kettering
red score:114 blue score:79 red: 2137 33 1 blue: 326 67 3322 red mini:50 blue mini:15
Top teams, or top robots? You mention both in the opening post.
The other top NJ score
red score:124 blue score:36 red :2016 1676 303 blue: 1302 2180 816
Since everyone is talking about avg qualification score, I figured I would post Top 30 OPR. I made this using version 13 on each regional and compiling it using Excel (while Bongle is working on a new version for this year).
Rank	Team	OPR	Event
1	33	56.7075	GG
2	148	56.5229	STX
3	217	54.4144	ROC
4	2056	52.7503	ROC
5	1676	46.3775	NJ
6	2016	45.5644	NJ
7	1218	45.5229	NJ
8	1126	43.2325	ROC
9	1519	40.1307	NH
10	131	38.6893	NH
11	16	38.4332	STX
12	40	34.7814	NH
13	836	34.2788	NH
14	118	33.748	STX
15	1918	32.5715	GT
16	25	32.5498	NJ
17	229	32.3928	ROC
18	191	31.3583	ROC
19	1429	30.0761	STX
20	2848	29.419	STX
21	1089	28.689	NJ
22	2587	28.6853	STX
23	2137	28.6095	GG
24	1923	28.4289	NJ
25	245	28.249	STX
26	340	27.9883	ROC
27	69	27.961	NH
28	138	25.7975	NH
29	3074	25.7734	NH
30	2590	25.4736	NJ
OPR seems to be a good stat this year. Even though it only looks at qualification data, the team with the highest OPR won every event. Even this even applies to NH, where 1519 had the highest OPR, was picked 3rd overall and won. Keep in mind that OPR doesn’t have any way to connect between regionals, since no inter-regional matches are played.
