Does anyone know the sudo login for FRCVision?
It’s the default credentials for the Raspberry Pi image
Username: pi
Password: raspberry
Yes, that is the read only login. Is there any other login? I’m trying to do chameleon vision. Should I just use raspbian?
It’s the file system that is read only, not the user. If you call rw at the prompt, it will set the file system to read write. You can then call ro to make the file system read only again.
