FRCVision on Raspberry Pi: Help Accessing OpenCV
I can access the Web interface, but cannot get opencv code to work. How can I edit the python example program to output a opencv image? Any help would be appreciated.
https://docs.wpilib.org/en/latest/docs/software/vision-processing/raspberry-pi/the-raspberry-pi-frc-console.html#vision-workflows Has some helpful information.
To create a stream in Python, do this:
stream = CameraServer.getInstance().putVideo("Stream 2", WIDTH, HEIGHT)
To put a new image to the stream, do this:
stream.putFrame(frame)
Finally, you can view this stream at http://frcvision.local:1182
Since the Python stuff on the FRCVision uses RobotPy, take a look at the RobotPy documentation on CameraServer: https://robotpy.readthedocs.io/en/stable/vision/code.html
