FrSky Taranis use with Driverstation over USB
Is there any way possible to use the FrSky Taranis over USB with driverstation? and how would that look coding side?
Thanks
Davis Pitts
3577
To my personal knowledge, there’s no way that wouldn’t violate rules governing wireless controllers. However, if you’re willing to sacrifice one, you could probably open it up and wire it to a microcontroller able to act as a USB HID device, such as a 32 bit Teensy board or a Ti Launchpad.
You can use it as a regular usb device, without using the transmitter part, i’m just not sure how to access the controller through driver station. and code it in.
Sent from my iPhone using Tapatalk
And if i can use a Teensy board to set it up as a joystick in code, could you mentor me on how to do that?
