[FTC]: Buttons RobotC
I am trying to assign buttons to control a Tetrix DC motor when ever i assign 2 functions to control the same motor say one button forward and one backward the motor coughs and jumps and vibrates moving spastically. I attached the code below, how could i solve this problem?
if(joy2Btn(2) )
motor[motorF] = 100;
else
motor[motorF] = 0;
if(joy2Btn(1) )
motor[motorF] = -100;
else
motor[motorF] = 0;
Let’s break this down step by step:
What the above “if” is saying is “If Button 2 on Joystick 2 is pushed, set power to motorF to 100%. Otherwise, set it to 0”.
This one is saying “if Button 1 on Joystick 2 is pushed, set power to motorF to 100% in reverse. Otherwise, set it to 0”.
The problem is not with the if (true) conditions, it’s the else conditions that are conflicting with each other. If Button 1 is pressed, then button might or might be pressed, so motorF shouldn’t go (the else conditions). Likewise for Button 2.
A better way to right the code is:
if (joy2Btn(1))
else if (joy2Btn(2))
else
    motor[motorF] = 0;
Since the target of the conditional test is the same resource (motorF), you’ll have to keep the tests with the target in one condition.
Good luck!
Thanks this worked perfectly
