FTC Championships
Is there an online source for match results or qualifying standings for the FTC events? I can’t find one.
(If FIRST can stream real-time match results for FRC, why can’t they do the same for FTC?)
Rick,
They are not doing too good with FRC
Mike
They don’t care enough to?
The webcast is switching back and forth between four fields, so I’ve not been able to see our team compete once.
To make this an even more PNW thead. Is there a site that shows the match results?
-Jim
http://science.ksc.nasa.gov/robotics/
Webcast of All - FRC/FTC/FLL
The NASA site has a camera for each field. So you can watch a specific field.
There are four FTC fields across two divisions. They are alternating which division they stream, ten matches at a time. It does not get the same attention as FRC.
This was the original request:
I know where the Webcast is, but that’s not what I wanted. As Madison pointed out, it’s hard to watch for particular teams because they are only Webcasting half the matches.
