So I understand that we need to change the name on our NXT brick to our team number. How do I do this? Right now, it is set at the default, “NXT”. Thanks!
(a QUICK response would be appreciated, competition is kinda tmmrw, hehe, procrastination FTW.)
If you’re using RobotC, simply go to “Link Setup” connect your brick via USB, then click “Rename NXT”. After this, type in your team number, and you are good to go.
On a program, click the NXT brick icon (top left button) on the bottom right control palette. Choose the memory tab and on the right hand sidebar you can rename the NXT beside Name
