FTC Field Configuration
Hi, we just bought an FTC field from AndyMark and the perimeter after we assembled it is 11’ 1/4" and not 12’ is this normal? We tried everything and we can’t make it 12’. Is this a flaw with the Field? Thanks.
You’ll probably have better luck contacting them directly by phone or email.
From the field perimeter page here: http://www.andymark.com/FTC-Perimeter-p/am-0481a.htm
Specifications:
Inside Width: 11' 9"
Outside Width: 11' 11"
Height: 12.125"
Weight: 72 lbs.
The field is made of 12 panels http://www.andymark.com/FTC-Field-Panel-p/am-2160a.htm
Specifications:
Weight: 5.5 Pounds
Width: 46.375"
Height: 12"
Depth: 1"
Material: The metal rails are aluminum and the plastic is a polycarbonate sheet.
