[FTC]: FTC Encoder Program with Distance
Hello,
We are trying to program our Autonomous portion using distance with
TETRIX DC Motor encoders. The following is our program:
#pragma config(Hubs,  S1, HTMotor,  HTMotor,  HTServo,  HTMotor)
#pragma config(Motor,  mtr_S1_C1_2,     leftBottomDrive, tmotorTetrix, openLoop, encoder)
#pragma config(Motor,  mtr_S1_C4_1,     rightBottomDrive, tmotorTetrix, openLoop, reversed, encoder)
//*!!Code automatically generated by 'ROBOTC' configuration wizard               !!*//
task main()
	float diameterOfWheel = 3.96;//set the diameter of wheel to 3.96 inches
	float circumfirence = diameterOfWheel*PI;
	int distanceToGo = 12;//we want the robot to go one foot, or 12 inches
	float rotations = distanceToGo/circumfirence;
	int degreesToTurn = rotations*360;
	int encoderCounts = degreesToTurn*4;//encoder counts are in quarter degrees, so 4 encoder counts = 1 degree
	nMotorEncoder[leftBottomDrive] = 0;//motors do not run
	nMotorEncoder[rightBottomDrive] = 0;
	nMotorEncoderTarget[leftBottomDrive] = encoderCounts;//tell motors to go a foot
	nMotorEncoderTarget[rightBottomDrive] = encoderCounts;
	motor[leftBottomDrive] = 50;//go at power 50
	motor[rightBottomDrive] = 50;
	while(nMotorRunState[leftBottomDrive] != runStateIdle)
	motor[leftBottomDrive] = 0;//turn motors off
	motor[rightBottomDrive] = 0;
When testing the program, the motors drove unlimited instead of stopping after one foot.
Regards,
The Charging Champions
In pragma, change
to
#pragma config(Motor, mtr_S1_C1_2, leftBottomDrive, tmotorTetrix, PIDControl, encoder)
(or just check the box “PID control” in Motor and sensor setup). Obviously, you need to do this for both motors.
Sorry, we forgot to mention that we tried this. It worked on the right wheel, but on the left wheel, it was jerking around and did not move as smoothly.
Is this a building error or a wiring error?
Thanks,
Charging Champions
FTC Team 8660
I’d guess a building error, but can’t say without seeing the robot. Or maybe the encoder cable is damaged? if these are Tetrix motors, the encoder cable is very fragile.
