In LabView, we are attempting to make our servos move in increments for the duration that we press a button. However, with our current code, we are able to press a button, and upon that press, have our servo move to a set position. We would like to know how to “store” a variable and add a set number to it so that it moves the servo up/down in our set increment as long as our button is still pressed.
We are a rookie team, and have never used LabView before. All tips and suggestions are welcome!
Here is an example i drew up for you guys. To make it go reverse, just put another case structure in there. I am with FRC, but the logic should be the same.
This example shows how you can use two game-pad buttons to incrementally increase and decrease the position value of a servo. The example also shows an efficient method of using a case structure with the FTC Read Buttons VI rather than using nested case structures.
