Hello, i was working on getting two inverted wheels to move same direction under move a fixed distance, is their anyway i can do that
Can you define inverted in your application? Perhaps post an image?
Hi
If your wheels are inverted, then the last digit in their motor specification should be different…
eg: 1110 and 1121
Wheel port 1, controller 1, motor 1, not inverted
Wheel Port 1, Controller 1, Motor 2, Inverted
Then telling both wheels to move 1000 counts will travel forward.
Is that what you mean?
Phil.
