watching some FTC Matches videos I noticed this
I hope they moved beacon back
Isonine
That’s a new one. Didn’t see any of that happen last year. Hopefully it’s not a reoccurring theme?
Whoever was in charge of setting up the field, did not do a good job. The whole field is out of spec.
- White Lines are 2in, suppose to be 1in
- Corner Vortex as not flat on the ground
- Manufacturing plastic covering still on the clear deflection shields under the center vortex goals.
- The deflection shields are really crooked
5) Beacons aren’t bolted down (Hence the moving)
- Beacon Images below are just slapped on and crooked.
TEAMS: If you see this at your event. You can request them to fix it. The field is not in spec.
This x100. I know how much work goes into setting up the field, but that field is far out of spec for all of those reasons.
Additionally, the red/blue tape in the center is supposed to be 100% on the center vortex base plate.
