[FTC]: Overall goal size?
Hello,
My FTC team (Team 6095) is trying to build the center goal, but not out of pvc. We are going to build the backing out of plywood, and attach the pvc to it because of the materials we have. Can anyone tell me the overall size of the center goal and where each peg is?
Thanks!
This thread answers that.
If not, this video will.
If that doesn’t
Then her are the Field Drawings.
http://www.usfirst.org/sites/default/files/uploadedFiles/Robotics_Programs/FTC/Game_Info/2012/Ring-it-Up-Build-Guide.pdf
Hope this helps.
  • Andrew
Why not just make one of the PVC coulmns that go up out of the actual PVC? You could build that for less than $20 dollars. Plus the bottom peg is the same height as the dispenser and corner goal. Plus its alot more accurate.
