[FTC]: Tether Testing
Hey, anyone know how, or can provide instructions on how to test the 2010 FTC robot tethered to our computer? Our wireless isn’t working and we want to test out our programming to see if it works correctly.
Just connect the USB-A to USB-B cable to the brick and your computer and you should be able to connect just fine. Also if wireless isn’t working, it is a problem you need to figure out, but you can always use bluetooth like in past years, there should be no difference in the robots behavior between these three choices.
Hope that helps
