[FTC]: TETRIX gear specs
For posterity:
TETRIX gears have a diametral pitch (DP) of 32 teeth/in, a pressure angle (PA) of 20 degrees, and a face width of 0.250 in.
I’m lost as to what the purpose of this was?
I thought I explained it pretty succinctly… I needed this information and I couldn’t find it on ChiefDelphi or any other obvious place. So after doing the research to find the information, I shared it here for other people to use because I couldn’t find a more appropriate place.
thank you for this info i found it usefill
I think they’re actually 0.80 module based on the dimensions of the CAD models that I downloaded. 0.80 module is equivalent to 31.75 pitch, so a custom 32 DP gear would work fine in any case. I’m not positive that the models match reality. If one measures the outer diamter of a 40 tooth gear, then if it’s closer to 1.313" it’s 32 dp, and if it’s closer to 1.323" it’s 0.80 module.
Adding my thanks for storing this data. Just what I was looking for!
Emphasis added. Thanks Dan and Randy for correcting me.
