Gearbox Calculations
Hey, I am having a hard time determining output speed and torque from the CIM-U-LATOR gearbox using the 2 RS-550 banebots motors. Can anyone explain what formulas I need to determine this? All help is appreciated.
First step is to count teeth.
I haven’t used or seen a Cim-u-lator, but looking at the Banebots website it states that it has a 2.7:1 gear reduction. With a 10 tooth pinion on the motors driving a 27 tooth gear on the output shaft.
If the tooth counts match what the website says then you can use the following formula to determine the output speed.
Ratio=# Teeth in Gear/# Teeth in Pinion
Output Shaft Speed=Motor Speed/Ratio
Output Torque=Motor TorqueRatio(Number of Motors)
Single Reduction gearboxes spur gearboxes are relatively efficient so you can probably neglect any losses from the gears in your calculations.
It is probably worth stating that the motor speed is very dependent on load and so I typically suggest using a timing light to actually measure output speed. The formulas will usually get you in the ball park.
Banebots 550-12:
19,300 rpm free speed
70.5 ozin stall torque
85 stall amps
CIM-U-LATOR:
Gear reduction is 2.7:1
… so 2 550’s on a CIM-U-LATOR would be
free speed = 19,300/2.7 = 7148 rpm*
stall torque = 270.52.7 = 381 ozin*
stall amps = 2*85 = 170 amps
Is that what you were asking?
  • neglecting gearbox efficiency losses
Yes, thanks for the help
You can enter those numbers:
free amps = 2.8 amps
… into the motor calculator using option “u” (UserDefined motor):
Motor Calculator  build MCALC32ae 2/21/2012 117am
Select motor:
1)CIM      6)FP0673   d)FP2719   f)FP9012    g)FP9015    h)FP9013
a)am-0912  b)am-0914  7)DensoL   8)DensoR    c)Denso0160 u)UserDefined
2)RS395    3)RS540    4)RS550    e)RS775-12  5)RS775-18  x)exit u
Enter the following motor specs in the order and units indicated,
separated by spaces or tabs:
volts   stall_ozin      free_rpm        stall_amps      free_amps
12      **381 **            **7148**            **170**             **2.8**
UserDefined-> 12.0 381.0  7148 170.0  2.8 @ 12.00 volts:
@ free (no load):
   oz-in      Nm     rpm    rpm%    amps   watts out  watts heat    eff%
     0.0   0.000    7148   100.0     2.8         0.0        33.6     0.0
@ stall:
   381.0   2.690       0     0.0   170.0         0.0      2040.0     0.0
@ max power:
   190.5   1.345    3574    50.0    86.4       503.5       533.3    48.6
@ max efficiency:
    43.3   0.306    6335    88.6    21.8       203.0        58.8    77.5
Select input:
1)oz-in  7)watts_in    3)rpm    5)amps   8)eff%
2)Nm     6)watts_out   4)rpm%   9)volts  a)rpm&ozin   b)rpm&amps
… and then you can do calculations to determine the operating point under various conditions of speed, load , or applied voltage.
