Gearbox -physics related question
If you had two identicle systems (wieght, support…) and two wheels that have the same weight but wheel A has less rotational inertia than wheel B, then no, they would spin up to the same speed. However wheel A will take less time to get up to speed than wheel B. However, if you got both wheels up to speed turned off the power, then tried to shoot a ball with the momentum of the wheel (say in 2006), wheel A would shoot fewer balls than wheel B.
In reallity wheel A or gear A would probably also wiegh less, so would put less strain of the system and it might be better balanced which would also reduce stress and so on. So in a real system like a shooter the rotational inertian of the wheel would have a huge effect on the efficiency of the system.
However in a drive train the gears shouldn’t be big enough to make a difference. So I will calculate the time it would take the first big gear in the am planetary to spin up. This gear spins at 1540 RPM or 161.26 Radian/sec
m = ~.31kg
w (omega) = 161.26 Radians/sec
I = (mr^2)/2 = 1.562 E-4
T (average) = ~3.95 Nm
in this cas Torque (T) = Moment of Inertia (I) * angular acceleration (a)
so a (alpha) = T/I = 25280 Radians/sec^2
angular velocity (w) = angular acceleration (a) * time (t)
so t = w/a = .00636 seconds
A 120 pound robot (I know its actaully more like 133 lbs) with a reduction of 1:12.75 (AM single speed) to a four inch wheel on the other hand will take:
m = 54.54 kg
F (average) = ~138.04 N
a = F/m = 2.531m/sec^2
vFinal = 2.295 m/s
t = v/a = .907 seconds
So the gear wil take .00636 seconds to spin up and the robot will take .907seconds to accelerate (under absolutely idea situations). There are some assumptions in this. If anyone thinks these assumptions are too extreme, sees a mistake in my math or wants to know where I got a number please PM me.
So since the time of acceleration of the bot is huge compared to the gear it really doesn’t make a difference. However you can see that the gear would slow the robot down a little.
In the case of a car there is a much bigger difference because your talking about a 50 lbs fly wheel not a half pound gear. So your theory is correct but I would always sugjest doing to math cause you’ll see if you actaully need to think about implimenting it. To do this you should calculate the acceleration of the robot with two different gears (one lightened, one not) and see if there is a difference.
hope that helps
Alex
Bzuhhh… Just making sure… In your conceptual post you’re ok…
But as stated above (and its so important i’ll restate it) F is a force. Hp is a rate of energy conversion. 2000RPM is a speed, while 2000RPM/s is an acceleration. 2 lbs is a force, while 0.0622slugs or 0.9072kg is a mass.
And, to reaffirm, yeah the rotational inertia of the AM gearbox is negligable… as well as the rest of your drivetrain (unless you have some gigantic flywheel your storing energy in). Just worry about the mass of your robot.
-q
Also, I hadn’t thought enough about your theory above, and no it is not actually true. Lightening the gear would not speed up the output.
The limiting factor in the speed of the system is the max RPM of the motor which is a result of motor design. The CIM won’t spin any faster than ~5200 RPM or so even if there is no pinion gear or drive train or anything.
When I calculated the time above I was using your equation F = m*a. This relates to a force, a mass, and an acceleration. acceleration is only applicable to speed when introduce time. The reason that the motor won’t spin the gear faster is because as the output RPM of the motor increases the torque decreases to 0 at the max RPM of the motor.
Again, hope it helps
Alex
Alex is correct. Thats why I said in theory that this idea works but there is a limit too it.
As noted, the rotational inertia of most all gearboxes in FIRST are negligible. And if you lightened the gearbox with everything else the same, your max speed would remain the same, though the robot would accelerate slightly faster. The best way to think about it is as a division of kinetic energy. Assuming you have a flywheel attached such that it spins faster the faster your robot moves, the flywheel would store some amount of rotational kinetic energy for every Joule of translational kinetic energy stored by your robot moving forward. With a standard gearbox, it’s probably something like .01 J of rotational energy for every 1 J of translational. With a big flywheel, you’d be storing more in the flywheel, and a comparatively smaller amount of every J from your motor would be going towards actually moving the robot forward.
To correct one error I’ve sen in this thread. The top speed of your robot does not depend on the max RPM of the motor. It depends on the friction in your drivetrain. The friction represents a torque that must be subtracted from the torque developed by the motor before you start firguring the acceleration of the robot. So at some point, the torque put out by the motor equals the friction torque, and your robot stops accelerating. Since the motor is putting out mre than zero torque, this isn’t going to be the no-load speed.
ok thanks for all the help
once again this is all just theory, im just trying to find out if what im saying is even ballpark
and this isnt just in relation to the gearboxes , but any rotating object on the bot.
Also , if the drive train is more efficent , less power is lost , and more gets to the wheels , thus some power is picked up … right
This all depends on how you define your motor. Technically no motor has a no load speed since the motor has to spin itself which takes some power input. Since the CIM has a resistance and you have to put power in which means that your producing power somehow. I think you could define the whole drive train as a motor, maybe a linear motor, and then say that the top speed of the robot is the free speed.
A lot of solving a problem in physics is just choosing the correct frame of reference and it might be easier to define the drive train as the motor and just measure its speed. I’m not sure what the use of this is but hey…
Alex
Putting a lighter flywheel on an engine in a car can result in better acceleration, because more of the power made by the engine is being used to move the whole car, rather than just increase the rotational inertia of the flywheel.
However, the power to the rear wheels at a constant speed will not be any different.
You have an interesting idea, even if it’s not likely to help robot performance, it at least shows you are thinking about new things! And asking questions like this will surely help you to better understand physics.
Thanks!
Well , if a car engine makes more power than the power to the rear wheels , DECREASING rotational inertia , and rotational mass decreases drive train power loss and makes the whole system more efficent
thats sorta what i was getting at with the gearboxes, wouldnt it be a bit more efficent and a bit more power gets to the wheels , i dont care if it is un noticable , its just a point , it could be a ball shooter from AIM HIGH
I wouldn’t really make it much more efficient because the energy is still in the system it is just keeping the gear turning instead of the robot translating.
The energy will go towards making the robot move when you turn the motors off and let the robot come to a stop because this is when the robot will come to a stop.
In a car since the engine isn’t connected to the ground and the fly wheel keeps turning when the car comes to stop this just adds inefficiency to the system but for a robot and an electric motor it doesn’t have nearly as much effect on efficiency.
By the way, thanks for the question. I’ve been enjoying thinking about it.
Alex
this is an idea that sorta ticked my mind for about a year , the main thing that started my wondering was the 7 LB rear sprocket on my motor cycle. Now i knew i was gonna cut weight , but would it have more of an effect cutting it from the outside rather than closer to the center., so taling ot my physics teacher , we figured out off the normal drive train power loss i would get more power to the wheel VS, loosing it due to the motor having to exerct the force to get it moving and keep it moving
if that makes sense
what did you figure out? does it take more power to get it moving? what about to keep it moving?
In Aim High, our shooter was directly driven by the large
CIM motor. The RC measured the speed of the shooting
wheel and adjusted the motor power to tightly regulate
the speed. The desired speed was a function of measured
range to the target goal. The considerations that you
mention, properly doing the physics, were a fundamental
part of the design process. To obtain a fast spin up,
the rotational inertia of the ball shooting
wheel needed to be low. To have the ball shooting wheel
store enough energy that it could shoot the ball and not
stall, the rotational inertia of the ball shooting wheel needed
to be high. When all was said and done, we found the
right compromise for the rotational inertia that provided
a fast spin up and enough energy storage to shoot balls
without losing too much speed.
I would encourage you to pursue your study of physics
so that you develop a proper understanding of these things.
Eugene
ok like , if a car has a 50 lb flywheel , and you change it out to a 30 lb flywheel , you dont make any more horsepower , BUT more power gets to the wheels
same concept right?
is any of the stuff i have come up with remotely correct , cause thus far it seems really really really off
Nope - thats not exactly how it works.
Lets think of this in terms of a plumbing system. The motor generates power, think of it as a water supply.
Now, the goal here is to get the power output to the wheels - lets think of this as the faucet.
The flywheel would be analogous to a storage tank - if you turn on the water, it will first fill up the storage tank, and then after the tank is filled, it will come out of the faucet. Changing the rotational inertia of the flywheel(tank of water) doesn’t make a difference in how much power goes to the wheels - all it does is store energy.
If you make the flywheel smaller - then it takes less time for the wheel to reach full speed - but it will make no difference in total power.
This explanation might be a little confusing, but I hope this is helpful.
Actually, that’s entirely spot on. Inside of a FIRST drive train, by making all gear and wheel components lighter, you’ll gain acceleration. You won’t pick up any extra torque or power.
On a car, it’s somewhat different. The general rule is that for every powered pound you lose (brakes, axles, etc), you gain 1HP. For every 10 un-powered pound (seats, body, frame, etc), you gain 1HP. However, on a FIRST bot, we’re not dealing with nearly enough power to get anywhere close to that kind of gain.
Good method of explaining, 114Klutz.
Making a drive system light is a good thing to shoot for. If you’re really interested in lightning acceleration, do some research on the recent 254/968 drive system. Their entire gearbox weighed 1 pound. They were the fastest accelerating bot I’ve seen on the field.
actually it’s exactly the same! you won’t gain any power on a car by lightening components, you’ll just gain acceleration.
Right. I had posted pre-breakfast (always a bad thing for a growing teen like me…).
I’m kind of confused at what Horsepower is actually measuring. Is it a force measurement? Acceleration over time? If someone could shed light on that, it would be pretty cool.
Power is the amount of work done per unit of time.
Work is the application of force over a distance.
In the case of a car engine, horsepower is not actually measured directly, instead it is calculated as the product of torque and angular velocity (rpm)
then you should be wondering about why it is that torque and work have the same units :slight_smile:
Horsepower is a measure of power. Its just like a watt in and fact 1hp = 745.7 watts in mechanical terms. This is basically the amount of power that a horse can continuously put out.
But torque and work don’t have the same units. torque is Nm and work is the joule which equals 1 Nm… :smiley:
Alex
