I would. I used CAD geometry directly and didn’t check to see if it is symmetrical.
Thanks for designing these! I installed some of the PVC version during our field element build session today. The parts are a very tight fit requiring no glue, which is great, but we found they were potentially too tight. Ended up sanding them down a bit, which worked well.
I made a modified part that has a chamfer up to about halfway up the pvc interface, hopefully it will make them easier to install. Either way, they look great!!
Yeah, that is the trouble with 3D printed parts. Variance from machine-to-machine and even between different materials on the same machine can easily change a nice slip fit into either a sloppy mess or an impossible interference fit. That is why I always try to provide the CAD along with the STLs so that adjustments can be made to fit everyone’s needs. I hope they work well for you.
Ah this was on a Bambu X1C with ABS, same settings you recommended above. But yeah I suppose even different printers of the same brand can have variances.
The T-connectors were pretty straightforward, but the curved pieces did not have a good way to hammer in. If I have time I may try to come up with a jig that would make it easier to mallet
We “thickened” the PVC interface pieces by -0.005" (in radius) which turned them from quite difficult to still tight but just about perfect. We tip the hat for the time-savings that your work represented for us.
I made essentially the same replacement with PVC and 3D printed parts. I made it available here as a public document on Onshape. I created a variable for the insert diameter to make it easier to change. I removed a little material from the extrusion profile to allow for any elephant foot (which can also be deburred) and the top layer can make insertion more difficult. Here are a some suggestions to make printing and assembling these a little easier.
- Print several endcaps with different diameters to find the one that works best with your printer and filament. Either can make a difference with you final dimensions.
- Swab the PVC pipe interior with PVC pipe cement before inserting. This softens the PVC and makes it a little easier to insert. It also creates a very strong bond if you print the parts out of ABS.
- Another version of the pipe cement bonds to PVC and ABS. It is a little more expensive so I have been “sticking” with the standard PVC cement.
- To create a line for drilling the mounting holes on the PVC pipe, lay the finished assembly on a flat surface and drag the edge of a metal square along the pipe. Now mark the correct distance up the bottom of the assembly.
- Use these same holes to hang the pipe upside-down for painting.
- Split all parts to create to symmetric haves in your slicer.
I have been sliding one half of a connector in then the other. I found it a little easier to get one piece wedged in than two at once. I have not tried inserting both since I added the chamfers so that may not be an issue now.
If you have any suggestions, you can post them here with a reply. I would also appreciate a direct message if you find an error. All dimensions should be within 0.02 inches.
It’s not just printer difference but also difference in the pipe itself. Pipe form two different manufacturers or even batches can vary in size enough to make a difference.
My team printed these and they work perfectly. We ended up using a file for some of the PVC and added painters tape onto some of the other fittings to dial in the correct tolerance. No glue was required and was a fairly simple assembly.
