You can actually read the joysticks during disabled. I setup a snippet of code this week to read the driver joystick and check if the trigger is held for 3 seconds, and switch to a different autonomous routine.
For reference, here’s that chunk out of my code
static Timer button_combo_timer;
if (BUTTON_COMBO_SWITCH_AUTONOMOUS() == true)
button_combo_timer.Start();
else
button_combo_timer.Reset();
button_combo_timer.Stop();
if (button_combo_timer.Get() > 3.00)
switch (autonomousMode)
case AUTONOMOUS_MODE_1:
autonomousMode = AUTONOMOUS_MODE_2;
break;
case AUTONOMOUS_MODE_2:
autonomousMode = AUTONOMOUS_MODE_3;
break;
case AUTONOMOUS_MODE_3:
autonomousMode = AUTONOMOUS_MODE_1;
break;
default:
driverStationLCD->PrintfLine((DriverStationLCD::Line) 3, "Using 1");
break;
driverStationLCD->PrintfLine((DriverStationLCD::Line) 3, "Using 2");
break;
driverStationLCD->PrintfLine((DriverStationLCD::Line) 3, "Using 3");
break;
driverStationLCD->UpdateLCD();
