Getting non-IO data from DS to cRio
There is a tutorial at the NI site which shows how you can do the image processing on the Classmate. I then want to send the Targeting Info cluster back to the cRio. Can someone explain how to do that? I know in Java, you can write this info into the Network Table, but how do we do it in Labview?
The network tables just send TCP updates, so those same ports can be used for other communications.
And if I can find the time, I hope to put up a LV version of Network Tables before too long.
Greg McKaskle
