We need width and height of the rotated rectangle contour in OpenCV Python
What do you need exactly? The lengths of the major/min or axes of the rect? Or the values of the bounding box containg the rotated bounding rect?
If the first one the function you are looking for is here:
From there you should have a set of points. You can simply calculate the length of each edge using itertools and the distance formula , filter out the diagonal lengths. Then Bingo.
(you could also use a simplify contour function without the minimum bounding box function to get a simmilar effect)
when we print minAreaRect its like ((num, num), (num, num), angle) we find angle with minAreaRect[2] and that returns angle from it but we also want the width data for more accurate distance calculation
