"Getting Started" Benchtop Test Program Not Doing a Thing...
In the test program, nothing is happening on the robot. No motors move. The only change I made to the code was I reconfigured the motor IDs correctly on RobotDrive to correspond with the left and right motors on the robot.
Anyway, see the code:
#include <IterativeRobot.h>
#include <Joystick.h>
#include <LiveWindow/LiveWindow.h>
#include <RobotDrive.h>
#include <Timer.h>
class Robot: public frc::IterativeRobot {
public:
	Robot() {
		myRobot.SetExpiration(0.1);
		timer.Start();
private:
	frc::RobotDrive myRobot { 3, 4 };  // Robot drive system
	frc::Joystick stick { 0 };         // Only joystick
	frc::LiveWindow* lw = frc::LiveWindow::GetInstance();
	frc::Timer timer;
	void AutonomousInit() override {
		timer.Reset();
		timer.Start();
	void AutonomousPeriodic() override {
		// Drive for 2 seconds
		if (timer.Get() < 2.0) {
			myRobot.Drive(-0.5, 0.0);  // Drive forwards half speed
		} else {
			myRobot.Drive(0.0, 0.0);  // Stop robot
	void TeleopInit() override {
	void TeleopPeriodic() override {
		// Drive with arcade style (use right stick)
		myRobot.ArcadeDrive(stick);
	void TestPeriodic() override {
		lw->Run();
START_ROBOT_CLASS(Robot)
And this is the build log when running the code on our RoboRIO:
Buildfile: C:\Users\Aiden\Desktop\Robotics Team\FRC Workspace\Getting Started\build.xml
Trying to override old definition of task classloader
get-target-ip:
     [echo] Finding roboRIO, please ignore any [hostinfo] error messages
     [echo] Trying DNS: roboRIO-4104-FRC.lan
     [echo] Trying USB: 172.22.11.2
     [echo] Trying mDNS: roboRIO-4104-FRC.local
     [echo] Trying Static Ethernet: 10.41.4.2
 [hostinfo] Error retrieving remote host information for host:roboRIO-4104-FRC.lan.
     [echo] Resolved mDNS to 169.254.62.76
     [echo] roboRIO found at 169.254.62.76
dependencies:
     [echo] roboRIO image version validated
deploy:
   [delete] Deleting: C:\Users\Aiden\wpilib\cpp\current\lib\WPI_Native_Libraries.properties
      [scp] Connecting to 169.254.62.76:22
      [scp] Receiving file: /usr/local/frc/lib/WPI_Native_Libraries.properties
      [scp] Receiving: WPI_Native_Libraries.properties : 2177
      [scp] File transfer time: 0.0 Average Rate: ∞ B/s
      [scp] done
      [scp] Receiving file: /usr/local/frc/lib/User_Libraries.properties
      [scp] Caught exception: scp: /usr/local/frc/lib/User_Libraries.properties: No such file or directory
  [sshexec] Connecting to 169.254.62.76:22
  [sshexec] cmd : rm -f /home/lvuser/FRCUserProgram
  [sshexec] cmd : ldconfig
     [echo] [athena-deploy] Copying code over.
      [scp] done.
  [sshexec] cmd : killall -q netconsole-host || :
   [delete] Deleting: C:\Users\Aiden\wpilib\cpp\current\ant
etconsole-host.properties
      [scp] Receiving file: /usr/local/frc/bin/netconsole-host.properties
      [scp] Receiving: netconsole-host.properties : 127
      [scp] done
      [scp] done.
     [echo] [athena-deploy] Giving program CAP_SYS_NICE capability.
  [sshexec] cmd : setcap 'cap_sys_nice=pe' /home/lvuser/FRCUserProgram
     [echo] [athena-deploy] Starting program.
  [sshexec] cmd : . /etc/profile.d/natinst-path.sh; chmod a+x /home/lvuser/FRCUserProgram; /usr/local/frc/bin/frcKillRobot.sh -t -r;
  [sshexec] cmd : sync
BUILD SUCCESSFUL
Total time: 21 seconds
And this is the only error:
Description	Resource	Path	Location	Type
Program "C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin\amd64\cl" not found in PATH	Getting Started		Project Properties, C++ Preprocessor Include.../Providers, [CDT Cross GCC Built-in Compiler Settings] options	C/C++ Scanner Discovery Problem
And I’m pretty sure that error only applies to when I work with Visual Studio, which I don’t do.
And also, the Talon SRX’s lights alternate with orange LED. That may be an issue.
So what are we doing wrong? I try to understand ::rtm:: and I always say, “I’m gonna get stuff done today!” but the lack of user friendliness says, “That’s where your wrong kiddo”
It’s not obvious to me what the issue is. However, a few questions come to mind:
  • From the driver station be sure you’re running AUTONOMOUS mode and not Teleop or your intended AutonomousPeriodic won’t be running. Easy to miss this critical item.
  • Possibly use printf() statements in your Periodic code to print out that you’re <2.0 seconds and driving versus >2.0 seconds and not driving. Then look in the console to see those printf statements. If you do this, I’d also suggest a printf() in AutonomousInit so that you are certain to see a printf in console. Just a sanity check at least.
bob
The RobotDrive object by default uses PWM control. Are your Talon SRXs connected via PWM or CAN?
