Hey all!
Not to be a winer… but,
The goal cad files are not precision…
The tees used on the goals at the kickoff are sanitary TEEs and are not symetric as a TEE…
The dimension of a 1-1/2" PVC is OD= 1.9"
The Cad drawing for the short goal assembly is not what was at the kickoff, look closely!
My point is that if you use the lenghts (for the PVC) specified in the cad drawings and stock lists, the goals will not mount correctly on the bases…
Or at least it won’t be pretty…
I have CADed out the goals tube length based on actual dimentions of the sanitary tees and elbows based on the recesses of the fittings if requested, I will make this rough CAD file available to others…
Regards,
PETRRJ
