Ive created a google form for my scouthers, the problem is it puts all the data into one spreadsheet. So i created a second spreadsheet, that is supposed to import data from the first one, but only if the team number matches the value in A1. Ive found this, but im having trouble figuring out how to interpret this part of the function:
When you say you created a second spreadsheet, do you mean an entire separate document? Or just a different sheet within the same “workbook” (if we use excel terms)? If the other sheet is within the same workbook, you can skip using the importrange function (instead just directly referencing the sheet as shown below).
I helped my team get a similar sheets based scouting system set up this year, and the formula for getting all the entries from the form responses looks like this: =query(data!A2:AD310, CONCAT(CONCAT("select * where D = ", B1), "order by C"))
In our spreadsheet, B1 is the team number in the same sheet as this formula is located.
In the form responses, column D contains the team number, and column C contains the match number. The “data” sheet contains the responses to the form.
One thing I noticed when setting up our system this year is that the format of the query parameters changed slightly. While using “Col4” or “Col3” used to work in previous years, we had to change to referencing columns by their letters in that query string. Maybe that’s contributing to your problem?
Do you really need ALL the data in a second sheet/tab?
If you just want to find values, like max or average, for a scoring data you can set up calculations that pull data from another sheet.
I have 500+ rows of data from our scouts, and doing a data filter on columns can isolate a team, but doesn’t allow for calculations. So I created a cell (A2 on my sheet) on a second sheet where I can type in a team number. In another cell I’ve entered this formula:
It does not. Having no upper limit leaves it limitless. I have tested this with other functions, having no upper limit means that there will be no limit to the data it chooses from. also when writig this it gave visual feedback of what it was referencing, and that was correct.
I think you’ve got the wrong column in your query statement. It looks like the team number is actually in column E, so maybe that formula should be: =query(ScoreSheet!A2:I, CONCAT(CONCAT("select * where E = ", A1), "order by B"))
