Gradle fileTreeArtifact not replacing files
Hi all, gradle question for the experts. I’m fairly certain I’m just not googling the right terms, so figured I’d describe it here.
We have a set of extra files we are looking to copy from the local repo over to the roboRIO on every deploy. Build avoidance is great, but I’d be fine if we just blindly copied over the files each time. Gradle, however, is reporting that every time we attempt to run the deploy, the files are “up to date” and doesn’t attempt to copy them, even if we changed them relative to what is on the RIO.
For now we’re just ssh’ing into the roboRIO and removing the folder on the remote target any time we know we want the files to update, but this is not optimal for the build season.
The snippet of how we’re currently attempting to do it:
    artifacts {
        //Main roboRIO Java .jar artifact
        artifact('frcJava', edu.wpi.first.gradlerio.frc.FRCJavaArtifact) {
            targets << "roborio"
            // Debug can be overridden by command line, for use with VSCode
            debug = getDebugOrDefault(false)
        // Casserole WebServer support Files Deploy
        fileTreeArtifact('CasseroleWebServerFileDeploy') {
            targets << "roborio"                   // Web server should deploy to RIO
            files = fileTree(dir: './resources')   // Dev PC location for files
            directory = '/home/lvuser/resources/'  // RoboRIO location to deploy to
        //Build info file deploy
        fileArtifact('BuildInfoDeploy') {
            targets << "roborio"                  // build info should deploy to RIO
            file = file(BUILD_INFO_FILE)          // Dev PC location for file
So, the question: Is there any easy way to get the fileTreeArtifact() to “always copy”? Mark the files as always dirty, or never up-to-date? Or is there something more fundamental about what we’re doing that’s incorrect?
Two things:
Can you run with --debug and send me the log? Gradle checks for file changes by taking the MD5 sum of the two files.
You can skip the cache check by setting cache = null or cache = false in your artifact block. (Make sure you do this after doing the debug build, not before!)
Public followup: Seems like the issue was non-reproducible. Logs confirm in the alpha software the Hash-based mechanism for comparing files and only deploying changed ones is up and functional…
