This is the output while the program is building, ive had this go on for 7 minutes before i killed it, it never completely finishes.
Executing task: gradlew deploy -PteamNumber=358 --offline -Dorg.gradle.java.home=“C:\Program Files\Java\jdk-13.0.1” <
Starting a Gradle Daemon, 3 incompatible Daemons could not be reused, use --status for details
Task :discoverRoborio
Discovering Target roborio
Using [email protected]:22 for target roborio
Task :deployNativeLibsRoborio
Artifact skipped…
Task :deployRoborioCommandsRoborio
-C-> sed -i -e ‘s/^StartupDLLs/;StartupDLLs/’ /etc/natinst/share/ni-rt.ini @ /home/lvuser
-[-1]->
Task :deployFrcStaticFileDeployRoborio
-C-> mkdir -p @ /home/lvuser/deploy
-[-1]->
1 file(s) are up-to-date and were not deployed
Task :deployFrcJavaRoborio
-C-> . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t 2> /dev/null @ /home/lvuser
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\libs\2020-intellij.jar → 2020-intellij.jar @ /home/lvuser
Task :deployJreRoborio
-C-> if [[ -f “/usr/local/frc/JRE/bin/java” ]]; then echo OK; else echo MISSING; fi @ /tmp
-[-1]-> MISSING
Deploying RoboRIO JRE (this will take a while)…
-F-> C:\Users\Public\wpilib\2020\maven\edu\wpi\first\jdk\roborio-2020\11.0.4u10-2\roborio-2020-11.0.4u10-2.ipk → frcjre.ipk @ /tmp
Task :deployNativeZipRoborio
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\opencv-cpp-3.4.7-2-linuxathena.zip_cdac89b3de9eb20812a0da59c2a33aaa\linux\athena\shared\libopencv_imgproc.so.3.4 → libopencv_imgproc.so.3.4 @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\opencv-cpp-3.4.7-2-linuxathena.zip_cdac89b3de9eb20812a0da59c2a33aaa\linux\athena\shared\libopencv_java347.so → libopencv_java347.so @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\opencv-cpp-3.4.7-2-linuxathena.zip_cdac89b3de9eb20812a0da59c2a33aaa\linux\athena\shared\libopencv_ml.so.3.4 → libopencv_ml.so.3.4 @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\opencv-cpp-3.4.7-2-linuxathena.zip_cdac89b3de9eb20812a0da59c2a33aaa\linux\athena\shared\libopencv_objdetect.so.3.4 → libopencv_objdetect.so.3.4 @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\opencv-cpp-3.4.7-2-linuxathena.zip_cdac89b3de9eb20812a0da59c2a33aaa\linux\athena\shared\libopencv_photo.so.3.4 → libopencv_photo.so.3.4 @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\opencv-cpp-3.4.7-2-linuxathena.zip_cdac89b3de9eb20812a0da59c2a33aaa\linux\athena\shared\libopencv_shape.so.3.4 → libopencv_shape.so.3.4 @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\opencv-cpp-3.4.7-2-linuxathena.zip_cdac89b3de9eb20812a0da59c2a33aaa\linux\athena\shared\libopencv_stitching.so.3.4 → libopencv_stitching.so.3.4 @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\opencv-cpp-3.4.7-2-linuxathena.zip_cdac89b3de9eb20812a0da59c2a33aaa\linux\athena\shared\libopencv_superres.so.3.4 → libopencv_superres.so.3.4 @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\opencv-cpp-3.4.7-2-linuxathena.zip_cdac89b3de9eb20812a0da59c2a33aaa\linux\athena\shared\libopencv_video.so.3.4 → libopencv_video.so.3.4 @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\opencv-cpp-3.4.7-2-linuxathena.zip_cdac89b3de9eb20812a0da59c2a33aaa\linux\athena\shared\libopencv_videoio.so.3.4 → libopencv_videoio.so.3.4 @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\opencv-cpp-3.4.7-2-linuxathena.zip_cdac89b3de9eb20812a0da59c2a33aaa\linux\athena\shared\libopencv_videostab.so.3.4 → libopencv_videostab.so.3.4 @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\hal-cpp-2020.1.2-linuxathena.zip_2ea52601ed94abd62ff18abb7005e2a4\linux\athena\shared\libwpiHal.so → libwpiHal.so @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\hal-cpp-2020.1.2-linuxathena.zip_2ea52601ed94abd62ff18abb7005e2a4\linux\athena\shared\libwpiHaljni.so → libwpiHaljni.so @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\wpiutil-cpp-2020.1.2-linuxathena.zip_ced5cd18547f69d04217b8a2b99b1cda\linux\athena\shared\libwpiutil.so → libwpiutil.so @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\wpiutil-cpp-2020.1.2-linuxathena.zip_ced5cd18547f69d04217b8a2b99b1cda\linux\athena\shared\libwpiutiljni.so → libwpiutiljni.so @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\ntcore-cpp-2020.1.2-linuxathena.zip_230ce3f1532b4765cea0f4ae5fe31717\linux\athena\shared\libntcore.so → libntcore.so @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\ntcore-cpp-2020.1.2-linuxathena.zip_230ce3f1532b4765cea0f4ae5fe31717\linux\athena\shared\libntcorejni.so → libntcorejni.so @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\cscore-cpp-2020.1.2-linuxathena.zip_fffb88f803a9e9685b164d4a1d7b1b84\linux\athena\shared\libcscore.so → libcscore.so @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\cscore-cpp-2020.1.2-linuxathena.zip_fffb88f803a9e9685b164d4a1d7b1b84\linux\athena\shared\libcscorejni.so → libcscorejni.so @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\cci-5.17.3-linuxathena.zip_f29e86dadf7e2d7b8e2e1d875f4d8e70\linux\athena\shared\libCTRE_PhoenixCCI.so → libCTRE_PhoenixCCI.so @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\diagnostics-5.17.3-linuxathena.zip_e9f312736ca3f4118de2b62dd3cc2baf\linux\athena\shared\libCTRE_PhoenixDiagnostics.so → libCTRE_PhoenixDiagnostics.so @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\core-5.17.3-linuxathena.zip_f48566fd569d548f64276091064ad9ed\linux\athena\shared\libCTRE_PhoenixCore.so → libCTRE_PhoenixCore.so @ /usr/local/frc/third-party/lib
-F-> C:\Programming Projects\Robotics\2020\2020-intellij\build\tmp\expandedArchives\SparkMax-driver-1.5.1-linuxathena.zip_720f144c6120693f94d3d8bf7b40351d\linux\athena\shared\libSparkMaxDriver.so → libSparkMaxDriver.so @ /usr/local/frc/third-party/lib
<=========----> 73% EXECUTING [43s]
IDLE
:deployJreRoborio
IDLE
