This issue stumped for me some time as when I reinstalled VSC and WPILib, I still received the same WPILib header errors when I built. However, I discovered that GradleRIO was actually trying to find x86 libraries and failing as they were not installed on my x64 system. I fixed this problem by importing the project, but even new projects have this problem until I import them. How do I resolve this?
Did you use the WPILib installer? If you didn’t, its possible gradle is picking up a 32 bit jdk, which will cause wpilib to use 32 bit libraries. Definitely recommend using the installer, as it sets everything up correctly and solves many of these issue.
Yes, all the installations have been done using the windows installer for WPILibs.
Can you post a copy of the build.gradle before and after importing?
