Every time I try and build the robot code I get this error. Here is the terminal output:
'gradlew' is not recognized as an internal or external command,
operable program or batch file.
The terminal process terminated with exit code: 1
The project is code pulled directly from a GitHub project and no changes have been made. The code builds on the other workstation too.
Any help would be appreciated, Thanks
Edit: I had the wrong folder opened as the base folder in the workspace. Thanks to Thad_House for his help.
Are you opening the correct folder in vscode? You need to have the folder with build.gradle and gradlew.bat open as the root of vscode. It cannot be in a subfolder. You have gradlew.bat too, right?
Where are you building it? In Visual Studio Code, Windows Command Prompt, or a Linux terminal?
I am running it in visual studio code.
Here is a picture of the tree view. Do I have the project opened correctly?
I had the wrong folder opened. I opened one too many folders upstream.
Yup, you had the wrong folder. We’re going to put some warnings in the next vscode patch to help teams with issues like that.
Hello,
We are having the same issue. Can we video chat or can you walk us through how you fixed the problem. Thanks.
Bionic Broncos - 6686
File->Open Folder
Choose the top level folder for the project that has the gradle stuff in it.
