GRIP and Smart Dashboard issues
I’ve been trying for several hours to get this working. I’ve setup a project just to test GRIP by tracking a can of Mountain Dew and it’s working perfectly.https://i.imgur.com/3OznBEs.png The robot sees it, the myContoursReport is populated every time the can is in frame. But I cannot for the life of me figure out how to get the GRIP data to display on the SmartDashboard. I’ve downloaded and installed the GRIP Extension, put the proper address into it and the publish video Operation Palette from GRIP. But no matter what changes I try it’s just gives me a “Connection refused: connect” error in the GRIP video pane.https://i.imgur.com/SWnkWC0.png I am confused as to what other options I have as of now.
Grip Pipeline code:
package org.usfirst.frc.team3393.robot.vision;
import java.io.File;
import java.io.FileWriter;
import java.io.IOException;
import java.util.ArrayList;
import java.util.List;
import java.util.Map;
import java.util.stream.Collectors;
import java.util.HashMap;
import org.opencv.core.*;
import org.opencv.core.Core.*;
import org.opencv.features2d.FeatureDetector;
import org.opencv.imgcodecs.Imgcodecs;
import org.opencv.imgproc.*;
import org.opencv.objdetect.*;
import edu.wpi.first.wpilibj.vision.VisionPipeline;
* GripPipeline class.
* <p>An OpenCV pipeline generated by GRIP.
* @author GRIP
public class GripPipeline implements VisionPipeline {
	//Outputs
	private Mat blurOutput = new Mat();
	private Mat normalizeOutput = new Mat();
	private Mat hsvThresholdOutput = new Mat();
	private ArrayList<MatOfPoint> findContoursOutput = new ArrayList<MatOfPoint>();
	private ArrayList<MatOfPoint> filterContoursOutput = new ArrayList<MatOfPoint>();
	private ArrayList<MatOfPoint> convexHullsOutput = new ArrayList<MatOfPoint>();
	static {
		System.loadLibrary(Core.NATIVE_LIBRARY_NAME);
	 * This is the primary method that runs the entire pipeline and updates the outputs.
	public void process(Mat source0) {
		// Step Blur0:
		Mat blurInput = source0;
		BlurType blurType = BlurType.get("Box Blur");
		double blurRadius = 4.504504504504505;
		blur(blurInput, blurType, blurRadius, blurOutput);
		// Step Normalize0:
		Mat normalizeInput = blurOutput;
		int normalizeType = Core.NORM_MINMAX;
		double normalizeAlpha = 0.0;
		double normalizeBeta = 255;
		normalize(normalizeInput, normalizeType, normalizeAlpha, normalizeBeta, normalizeOutput);
		// Step HSV_Threshold0:
		Mat hsvThresholdInput = normalizeOutput;
		double] hsvThresholdHue = {42.01012071698573, 88.46580642806299};
		double] hsvThresholdSaturation = {64.20863309352518, 255.0};
		double] hsvThresholdValue = {55.03597122302158, 248.47269624573377};
		hsvThreshold(hsvThresholdInput, hsvThresholdHue, hsvThresholdSaturation, hsvThresholdValue, hsvThresholdOutput);
		// Step Find_Contours0:
		Mat findContoursInput = hsvThresholdOutput;
		boolean findContoursExternalOnly = false;
		findContours(findContoursInput, findContoursExternalOnly, findContoursOutput);
		// Step Filter_Contours0:
		ArrayList<MatOfPoint> filterContoursContours = findContoursOutput;
		double filterContoursMinArea = 15.0;
		double filterContoursMinPerimeter = 15.0;
		double filterContoursMinWidth = 10.0;
		double filterContoursMaxWidth = 1000;
		double filterContoursMinHeight = 10.0;
		double filterContoursMaxHeight = 1000;
		double] filterContoursSolidity = {0.0, 100.0};
		double filterContoursMaxVertices = 1000000;
		double filterContoursMinVertices = 0;
		double filterContoursMinRatio = 0;
		double filterContoursMaxRatio = 1000;
		filterContours(filterContoursContours, filterContoursMinArea, filterContoursMinPerimeter, filterContoursMinWidth, filterContoursMaxWidth, filterContoursMinHeight, filterContoursMaxHeight, filterContoursSolidity, filterContoursMaxVertices, filterContoursMinVertices, filterContoursMinRatio, filterContoursMaxRatio, filterContoursOutput);
		// Step Convex_Hulls0:
		ArrayList<MatOfPoint> convexHullsContours = filterContoursOutput;
		convexHulls(convexHullsContours, convexHullsOutput);
	 * This method is a generated getter for the output of a Blur.
	 * @return Mat output from Blur.
	public Mat blurOutput() {
		return blurOutput;
	 * This method is a generated getter for the output of a Normalize.
	 * @return Mat output from Normalize.
	public Mat normalizeOutput() {
		return normalizeOutput;
	 * This method is a generated getter for the output of a HSV_Threshold.
	 * @return Mat output from HSV_Threshold.
	public Mat hsvThresholdOutput() {
		return hsvThresholdOutput;
	 * This method is a generated getter for the output of a Find_Contours.
	 * @return ArrayList<MatOfPoint> output from Find_Contours.
	public ArrayList<MatOfPoint> findContoursOutput() {
		return findContoursOutput;
	 * This method is a generated getter for the output of a Filter_Contours.
	 * @return ArrayList<MatOfPoint> output from Filter_Contours.
	public ArrayList<MatOfPoint> filterContoursOutput() {
		return filterContoursOutput;
	 * This method is a generated getter for the output of a Convex_Hulls.
	 * @return ArrayList<MatOfPoint> output from Convex_Hulls.
	public ArrayList<MatOfPoint> convexHullsOutput() {
		return convexHullsOutput;
	 * An indication of which type of filter to use for a blur.
	 * Choices are BOX, GAUSSIAN, MEDIAN, and BILATERAL
	enum BlurType{
		BOX("Box Blur"), GAUSSIAN("Gaussian Blur"), MEDIAN("Median Filter"),
			BILATERAL("Bilateral Filter");
		private final String label;
		BlurType(String label) {
			this.label = label;
		public static BlurType get(String type) {
			if (BILATERAL.label.equals(type)) {
				return BILATERAL;
			else if (GAUSSIAN.label.equals(type)) {
			return GAUSSIAN;
			else if (MEDIAN.label.equals(type)) {
				return MEDIAN;
			else {
				return BOX;
		@Override
		public String toString() {
			return this.label;
	 * Softens an image using one of several filters.
	 * @param input The image on which to perform the blur.
	 * @param type The blurType to perform.
	 * @param doubleRadius The radius for the blur.
	 * @param output The image in which to store the output.
	private void blur(Mat input, BlurType type, double doubleRadius,
		Mat output) {
		int radius = (int)(doubleRadius + 0.5);
		int kernelSize;
		switch(type){
			case BOX:
				kernelSize = 2 * radius + 1;
				Imgproc.blur(input, output, new Size(kernelSize, kernelSize));
				break;
			case GAUSSIAN:
				kernelSize = 6 * radius + 1;
				Imgproc.GaussianBlur(input,output, new Size(kernelSize, kernelSize), radius);
				break;
			case MEDIAN:
				Imgproc.medianBlur(input, output, kernelSize);
				break;
			case BILATERAL:
				Imgproc.bilateralFilter(input, output, -1, radius, radius);
				break;
	 * Normalizes or remaps the values of pixels in an image.
	 * @param input The image on which to perform the Normalize.
	 * @param type The type of normalization.
	 * @param a The minimum value.
	 * @param b The maximum value.
	private void normalize(Mat input, int type, double a, double b, Mat output) {
		Core.normalize(input, output, a, b, type);
	 * Segment an image based on hue, saturation, and value ranges.
	 * @param input The image on which to perform the HSL threshold.
	 * @param hue The min and max hue
	 * @param sat The min and max saturation
	 * @param val The min and max value
	private void hsvThreshold(Mat input, double] hue, double] sat, double] val,
	    Mat out) {
		Imgproc.cvtColor(input, out, Imgproc.COLOR_BGR2HSV);
		Core.inRange(out, new Scalar(hue[0], sat[0], val[0]),
			new Scalar(hue[1], sat[1], val[1]), out);
	 * Sets the values of pixels in a binary image to their distance to the nearest black pixel.
	 * @param input The image on which to perform the Distance Transform.
	 * @param type The Transform.
	 * @param maskSize the size of the mask.
	private void findContours(Mat input, boolean externalOnly,
		List<MatOfPoint> contours) {
		Mat hierarchy = new Mat();
		contours.clear();
		int mode;
		if (externalOnly) {
			mode = Imgproc.RETR_EXTERNAL;
		else {
			mode = Imgproc.RETR_LIST;
		int method = Imgproc.CHAIN_APPROX_SIMPLE;
		Imgproc.findContours(input, contours, hierarchy, mode, method);
	 * Filters out contours that do not meet certain criteria.
	 * @param inputContours is the input list of contours
	 * @param output is the the output list of contours
	 * @param minArea is the minimum area of a contour that will be kept
	 * @param minPerimeter is the minimum perimeter of a contour that will be kept
	 * @param minWidth minimum width of a contour
	 * @param maxWidth maximum width
	 * @param minHeight minimum height
	 * @param maxHeight maximimum height
	 * @param Solidity the minimum and maximum solidity of a contour
	 * @param minVertexCount minimum vertex Count of the contours
	 * @param maxVertexCount maximum vertex Count
	 * @param minRatio minimum ratio of width to height
	 * @param maxRatio maximum ratio of width to height
	private void filterContours(List<MatOfPoint> inputContours, double minArea,
		double minPerimeter, double minWidth, double maxWidth, double minHeight, double
		maxHeight, double] solidity, double maxVertexCount, double minVertexCount, double
		minRatio, double maxRatio, List<MatOfPoint> output) {
		final MatOfInt hull = new MatOfInt();
		output.clear();
		//operation
		for (int i = 0; i < inputContours.size(); i++) {
			final MatOfPoint contour = inputContours.get(i);
			final Rect bb = Imgproc.boundingRect(contour);
			if (bb.width < minWidth || bb.width > maxWidth) continue;
			if (bb.height < minHeight || bb.height > maxHeight) continue;
			final double area = Imgproc.contourArea(contour);
			if (area < minArea) continue;
			if (Imgproc.arcLength(new MatOfPoint2f(contour.toArray()), true) < minPerimeter) continue;
			Imgproc.convexHull(contour, hull);
			MatOfPoint mopHull = new MatOfPoint();
			mopHull.create((int) hull.size().height, 1, CvType.CV_32SC2);
			for (int j = 0; j < hull.size().height; j++) {
				int index = (int)hull.get(j, 0)[0];
				double] point = new double] { contour.get(index, 0)[0], contour.get(index, 0)[1]};
				mopHull.put(j, 0, point);
			final double solid = 100 * area / Imgproc.contourArea(mopHull);
			if (solid < solidity[0] || solid > solidity[1]) continue;
			if (contour.rows() < minVertexCount || contour.rows() > maxVertexCount)	continue;
			final double ratio = bb.width / (double)bb.height;
			if (ratio < minRatio || ratio > maxRatio) continue;
			output.add(contour);
	 * Compute the convex hulls of contours.
	 * @param inputContours The contours on which to perform the operation.
	 * @param outputContours The contours where the output will be stored.
	private void convexHulls(List<MatOfPoint> inputContours,
		ArrayList<MatOfPoint> outputContours) {
		outputContours.clear();
			final MatOfPoint mopHull = new MatOfPoint();
				int index = (int) hull.get(j, 0)[0];
				double] point = new double] {contour.get(index, 0)[0], contour.get(index, 0)[1]};
			outputContours.add(mopHull);
The GRIP plugin for the SmartDashboard is for viewing the output of a Publish Video step. To send an image with the contours on it from your robot program, you’ll need to draw the contours on a blank image, then pass that image to an MjpegServer. There’s a lot of example code on the internet for drawing contours with OpenCV, so I won’t get into that here
Some basic code for getting a MJPEG server set up to publish the output of the convex hulls operation:
GripPipeline myPipeline = new GripPipeline();
MjpegServer contourServer = new MjpegServer("contours", 1189);
CvSource contourSource = new CvSource("contours", PixelFormat.kMPJEG, IMAGE_WIDTH, IMAGE_HEIGHT, 10);
Mat contourImage = new Mat(IMAGE_HEIGHT, IMAGE_WIDTH, CV_8SC1);
myPipeline.process(...);
List<MatOfPoint> hulls = myPipeline.convexHullsOutput();
// Draw the hulls on contourImage ...
contourSource.putFrame(contourImage);
You can use the shuffleboard that has full integration with cscore, but if you want, i can write an email for you with a example code with grip
