Hi Chief Delphi,
We’re having problems uploading our grip pipeline to the roborio. The error message is:
/usr/local/frc/JRE//bin/java -Xmx50m -XX:-OmitStackTraceInFastThrow -XX:+HeapDumpOnOutOfMemoryError -jar ‘/home/lvuser/grip.jar’ ‘/home/lvuser/project.grip’
Java HotSpot™ Embedded Client VM warning: INFO: os::commit_memory(0xb24a0000, 4194304, 0) failed; error=‘Cannot allocate memory’ (errno=12)There is insufficient memory for the Java Runtime Environment to continue.
Native memory allocation (mmap) failed to map 4194304 bytes for committing reserved memory.
An error report file with more information is saved as:
/home/lvuser/hs_err_pid3040.log
